increase trailer clearance
BaHa Traveler
I have a 2014  13ft. Scamp which I feel is too low to the ground.  The tanks don't empty well at some parks.  Has anyone successfully increased the clearance?    I'd be happy with even 4 to 6 inches more clearance.
bcsnave
bcsnave's picture
3inch lift
Perfect Casita has a 3 inch lift. ..if you can change a tire you can do this
http://www.perfectcasita.com/scdto9axliki.html
piperjim
Raised 4"
I raised our Scamp 5'er by 4" when we had the hitch modified.  The shop simply placed a 4" spacer between the axle and frame.  The shop did a great job and everything works perfectly, so I'd say it was successful.  I did need to build another set of steps that we use to enter/exit the Scamp!!
Good luck!
