body sag at the door
joezuerlein
can any one help with sag at the door i have hairline cracks above the left door on the shell i know it is bulge out some the belly band is lower on the right side of the door maybe the floor is getting soft over the time allowing it to drop a bit could you shim the frame rails under the shell to help this also my door has a 1 inch or so gap at the bottom of the door any ideas would be great i am just trying to give a bit of help i can not afford to spend to much right now
First Inspect
Inspect
Floor under front bench for rot. Frame for cracks, especially at the front bends. Look under the trailer at the frame ear for the door walkway support, Between the metal ear and shell there is a 3/4" piece of plywood that is glassed over to attach the shell to the frame ear make sure that is intact. The opening at the door bottom is usually about 1/2"  it isseal with a piece of 3/4" foam. If it is really sticking out the door may have to be re worked.
More labor than money to fix this issue. You need to post a picture of your issues. Cracks above door are more than likely caused by a dead axle and support issues
joezuerlein
body sag door area
Here are some photos off my scamp
Broken Frame
Your frame is broken. The hanger that ties the main frame to the (Horiz.) walkway frame member is broken. This is causing your sag. The square tube running outboard is an attempt to repair the sag. (That is an add on.) The problem is the support was welded to the unsupported Horiz. frame member. The rectangular tubing  laying on its side is suppose to be tied to the frame member below the upper floor. The plate metal hanger that is suppose to tie these frame members together is broken.
     It's hard to evaluate from the pictures but, put a jack under the horiz. frame member under the door walkway. Jack it up to close the gap in the plate metal hanger and weld if things line up. There appears to be cracking in the fiberglass tabbing that ties the metal frame ear to the shell. There is a piece of wood under the glassed in area which needs to be evaluated.
      The cracking in the shell above the door is due to the broken frame and movement. The broken frame is more than likely caused bt a dead axle.
Might be a fairly easy fix if things line up. Just be careful and don't burn up the trailer when welding around the fiberglass.
Good Luck
