Loose screws
trapperdave
Loose screws
When traveling the screws inside on the cupboards and door trim back out.What is the solution to keep them tight?Thanks Dave
debstaines
debstaines's picture
Last seen: 1 year 1 month ago
Same issue
every trip. Screws across the bottom of the kitchen cabinet back out. I have 3 to put back in after last weeks trip
Interested in the responses
Deb Staines
2016 16’, layout 4
'Rapscallion'
Good use for silicone sealant.
Put a little silicone sealant on the screw threads then reinstall. Kind of like lock tite for wood. If the wood is stripped out use a longer screw (same size) . The bottom cabinet screws screw into the edge of the OSB floor, not much there to bite into.
Last seen: 4 days 17 hours ago
Loose screws
We had the same problem.  I put some wood glue on the screws before reinserting then I had the trailer tires balanced to minimize shaking while traveling.  Both actions probably had an effect, but we have'nt had a loose screw since.
Lynn
trapperdave
loose screws
 Thanks for the rsponses.I will give her a try..Dave
