Refrigerator Replacement
KReed
KReed's picture
Last seen: 1 year 2 weeks ago
​My 2013 16’ Scamp standard Layout 4 had the large Dometic RM2410 installed in the cabinet designed as a closet. The original owners must have requested this modification because, according to the Scamp specs, this refrigerator is only available in the 16’ Deluxe model. I have a rivet issue with that cabinet and have come to the conclusion that placing the refrigerator in the closet is compromising the structure of the trailer in that location and consequently caused the cabinet to pull from the ceiling breaking the rivets (only two rivets hold the entire cabinet to the ceiling). Not surprising when oneconsiders that the refrigerator weighs at least 78 pounds and is installed into a cabinet designed to be a closet.
In the original specs the RM2193RB Dometic refrigerator is located in the cabinet next to the stove, which is at a lower center of gravity and also weighs at least 35 pounds less. I want to replace the refrigerator, but not sure if I should put the smaller one in the closet or where it belongs, which is below and to the left of the stove. I may not have a choice because the trailer has all the venting installed and side panels cut out for the larger fridge. I would have to patch and repair the side of the trailer by door, or maybe I could just leave the vent on the outside and seal it off inside the closet.  Then I’d have a faux vent :)
Has any one else experienced an issue like this or have any suggestions or comments?
Cheers
Last seen: 3 days 7 hours ago
Fridge
Without really looking at the trailer I'm speculating, but I'm averse to cutting more holes in the trailer to accomplish something where a hole already exists for that purpose. Just me, I'd re-engineer the smaller fridge into the current fridge location or remove and rebuild the existing fridge location to take away the stress points that are causing the problem.
KReed
KReed's picture
Fridge replacement
Thanks, Greg
Totally agree with you about cutting more holes in Odes. I also posted on FiberglassRV.com and response informed me that many 16' Scamp layout 4 have the 4.6cf fridge installed in the closet without problem. In Sept, Steve is working on the revamp with me and we will remove the fridge to see what is going on with the cabinet. At this time, we plan to pull the cabinet back into place and add additional rivets in the ceiling for reinforcement. We thought we'd add a drawer, if possible, in the extra space the will be gained by replacing the fridge with a smaller unit.
Thanks again! I so appreciate your input.
Krestine
