5th wheel stabilizer
Billy32303
Billy32303's picture
hi 5th wheelers. Wondering if using a 5th wheel stabilizer is necessary? Do you use one or not? Thanks, I am new to my 1986 Scamp 19.
Earl A.
Earl A.'s picture
ModeratorLifetime Member
Scamp Fifth Wheel Stabilizer
I had a 2007 Scamp 5er deluxe that I just sold.  After 7 years of using it without a front stabilizer, I finally decided I needed one.  The creaks,  groans and noises coming from the landing gear as I climbed into the loft, or twisted and turned at night, prompted me to do something about it.
I addressed this issue in a previous post and provided pictures of the project.
I found it worked really well and provided a solid base for the trailer.  I recommend one.  - - Earl
piperjim
Fifth wheel stabilizer
Billy:
I'm not sure if it's necessary, but I feel better using it!
And, I'm not nearly as industrious as Earl.  I just use a piece of wooden 2x4.  It's cut just a few inches shorter than the length would be if I were on a very level spot.  That way I can always add one of the several odd pieces of wood that I carry.
Like Earl, I recommend it, and it's drop-dead easy!!
Billy32303
Thanks for the info, think I
Thanks for the info, think I will look into getting something just as a piece of mind.
I use one of those. It is a
I use one of those. It is a tripod with a chain the length of which is adjusted to make the height of the ball hitch right. In order to use it when the height is low on a sloping site, I had to add a foot of chain. It works great, neither of the two of us liked the rocking when the other was sliding down the steps for those middle-of-the-night excursions. I had some 1/4 inch foam rubber with one sticky side and attached it to the top plate of the tripod, to increase the friction between it and the Scamp hitch. I  think it is worth the trouble of setting it up.
Billy32303
Stabilizer
Wondering I if there is one made with the 2inch ball? I looked around at Camping World today and did not see one that works. Any ideas, leads? Thanks all for your help!
