Squeaky door
Squeaky door
Just wondering if anyone has had to deal with a squeaky door? And what they did for it..Our door just sounds awful with this squeak and its embrassing to say the least when someone wants to see the inside and that thing squeaks like that on a new one. We did know if we should try spraying something on the hinges or not,guy we talked to at Scamp didnt seem to know what to do....Wish we lived closed to Mn we would take it to them :-)
Rich and Val
Squeaky Door
My door was doing the same thing.
Yesterday I put a very small squirt of WD40 on both the hinge pin and brass ball, wiped off the excess, and then moved the door back and forth a few times. The squeak disappeared immediately.
2015 13' Deluxe
Last seen: 12 hours 40 min ago
Squeaky Door
A drop of oil will do the same thing.  Even a little vegetable oil will work if it bothers you while out camping.
Lynn
Last seen: 8 hours 47 min ago
Graphite
Never have had to grease a squeek on a door yet, seems like I should have run into that by now.  smiley
I might consider trying graphite instead of an oil or silicone spray but all will probably work fine. The difference would be that the oil/silicone products attract dirt/dust, where the graphite is a dry powder and won't attract the dirt. Graphite is what you should use in your house door key locks when they get tight for the very same reason that the locks will gum up worse if oil products are used.
Having not tried the graphite yet on one of those Scamp ball hinges can't say for sure that it is a solution but it should work. I'm going to try some on the Scamp 5er later this summer.
How about the dry Silicone
How about dry Silicone spray? That's what I used on the slide runners of our 5th wheel trailer.
Good Suggestion
I might try that one as well.....  yes
Thank you all for the replies on squeaky door
 He will try something dry if he can find it,he's not a fan of putting anything oily or greasey on nothing,It will have to wait a few weeks now tho as we are on the way to Ks to house and puppy sit while family member goes in for a knee replacement and we left the Scamp at home in storage this trip
RocheACri woods
RocheACri woods's picture
Verdict on squeaky door solution?
So a couple years later what has worked best? My door sounds like a bad haunted house sound effect.
Squeaky door
Well we actually sold the Scamp and bought the Casita last year so i dont know what ever happened to the door making that noise. I think it must have quit because the new owener of it never said anything about it.Sorry i cant be of more help
