Scamp 13 Liquid Granite Table
Last seen: 6 days 19 hours ago
We loved the Giani Granite FG-GI SICILIAN Sicilian Granite Paint Kit For Countertops, Sicilian Sand so much in our Escape 17 countertop project  that we decided to try the Scamp 13 table with the remaining product.
First step after sanding and cleaning the table is to roller on the special primer base which is black. Step two is to start applying the colors with a loofa sponge:
After you get the color layers and pattern you want then 3 coats of Sealer and a couple of days of dry time.
enigma1083
enigma1083's picture
Last seen: 1 year 1 month ago
Curious
Great Job and a nice touch. I am curious does this product have to be applied on a horizontal surface or could it be applied to a verticle surface as well. I am thinking the FG on the cabinets.
Vertical
Thanks for the kind comments...
Yes, it will apply vertically or horizontally as you can do the backsplashes in place and tape them off according to the instructions. These are the materials that are listed on the Giani website that it should work with. Fiberglass is not listed, but similar material are.
  1. Traditional granite countertops and vanities
  2. Formica countertops and vanities
  3. Laminate countertops and vanities
  4. Corian countertops - see note below
  5. Butcherblock countertops
  6. Ceramic tile with grout lines- see note below
  7. Cultured marble vanities
  8. One piece sink and counter vanities
  9. Primed or painted wood - see note below
  10. Primed or painted drywall
  11. Cabinet inlays
  12. Table tops
  13. Mantels
I'd probably test it on a scrap or inconspicuous area of the fiberglass counters before proceeding. If you attempt the project I definitely want to see the results, it's a potentially cool idea.
Last seen: 1 year 1 day ago
Looks awesome
That table sure did turn out very very nice! It looks like a pro did it :-)
Table
Thanks Earlene,
The Pros on this one would be my daughter and the better half..  laugh
They will enjoy your comments.
