Electric questions
13 posts / 0 new
stephles scampers
Last seen: 11 months 4 weeks ago
Green goo on the pump for the shower and sink in the bathroom?
Hello,   Has any one have an issue with a green goo type stuff coming off the switch that turns on the pump for the show gray water?  If so how do you gain access to the back of the switch that is on the wall in the toilet-shower? There is a small panel that is behind the switch that I cannot figure out how to remove to gain access?  Any one have any answers on this??  Please let me know.. thank you,
Les
Les
vincentimes.69
Last seen: 11 months 3 days ago
My two cents on the original
My two cents on the original questions.
Use 30AMP when you can. You can run more appliances at the same time... Not sure what equipment you have though.
Not necessary to flip the trailer breakers all the time, leave them on.
1) turn your fridge power sources OFF (both 12v and 120v).
2) plug to 30Amp shore power
3) turn your fridge back ON using the 120v switch.
Note: the interior lights run on 12v battery power. The light above the kitchen is the only one using 120v and will work only when shore power is connected. At least it's like that on older scamps.
2001-16' Scamp
