Charging battery while towing - what does it?
15 posts / 0 new
Solari
Hi all,
I'm looking to upgrade my regular deep cycle battery to a Trojan t-105. I'll be charging it the majority of time with my existing Renogy 100w solar suitcase kit while boondocking (which is what I do most of the time with occasional shore power use).
My 2011 13' Scamp has the Progressive Dynamics PD9130 controller; I'll be plugging their Charge Wizard into it for better charging of the battery.
My question has to do with charging the battery while underway on the road. I know my 7 pin hook up supplies a charge -- does it go directly to the battery or does it route through the controller in the Scamp?
If not, is it recommended that I get a charge controller for the car? Ie Orion's 20A DC to DC one?
Muchero thanks for any clarity!
Ray
PS. I've been full time camping in the Scamp since 2016 and absolutely love it. The Scamp has been a champ handling whatever I dragged it through in remote areas. : )
Hoosier Scamper
Hoosier Scamper's picture
Not Direct
I believe it goes thru the controller/converter circuits, at least on newer models but maybe all of them... newer models also have a DC cut off master switch inside the trailer that (wiring-wise) is upstream of the controller or converters. When this switch is off, you can't recharge the battery. Call Scamp, they could give you info for your trailer VIN, year model, etc...
Carl
Sunfish
Sunfish's picture
Last seen: 12 months 2 days ago
If you have a 7-pin connector
If you have a 7-pin connector, the towing vehicle's alternator should charge the trailer's battery directly.  Your battery should charge fully if you are traveling many hours between camping.  You can check your trailer battery with an inexpensive voltage or multimeter.  If your towing vehicle came with a factory towing package, you may have a heavy-duty alternator to easily handle your vehicle and trailer.  When you are connected to shore power, the battery gets charged through the trailer's controller.
Last seen: 2 weeks 6 days ago
Not always a full charge
My f150 did not fully charge the Scamp battery. I added a dc to dc charger to get a full charge.
Herrmaaj
DC to DC charger installation
Questions about your DC to DC charger
1) Which model
2) Did you install the unit in your camper or tow vehicle?
DC to DC charger
This one but I set it to 10 amps, mine is in the Scamp, it needs a dry location.
https://www.amazon.com/dp/B07Q5VYPCF?ref_=ppx_hzsearch_conn_dt_b_fed_asi...
Herrmaaj
Thank you for your reply.  I can't find anyone locally to install one.  So I have to figure it out myself.
 So did you run wires from your car battery to your hitch and connect to your Scamp that way?
Scamp wiring
I used the Scamp wires. I did a plug system so that I could plug it back to original if the charger quit. I was not looking for higher current, only a higher voltage.
Joacchim
Joacchim's picture
Scamp wiring diagram
The wiring diagram on the Scamp website shows a direct connection from the vehicle to the battery.  On my 2002 13' Scamp there are 20A fuses at the battery and at the connection to the Scamp internal circuits.
https://www.scamptrailers.com/wp-content/uploads/OWNERS-MANUAL-2022.pdf
Much has changed in 20 years
There are several diagrams out here this may be closer to 2002.
Joacchim
Joacchim's picture
Same connection between car and Scamp
@ac0gv:  In your schematic, assuming the trailer connection is off to the lower left, it looks like the car's 12V supply goes directly to the battery and to the converter, same as my older schematic.
It's pretty hard to see mine, I wish the forum offered a better way to view attachments.
