Brake grounding connections
Tom in NM
Last seen: 2 weeks 21 hours ago
I wanted to highlight an issue I've encountered. I ordered my 2021 13' with brakes (built in the second half of 2020) and I've been pleased with them.
Two years ago while doing some other maintenance, I noticed a dangling wire with a connector by the drivers side wheel. It turned out to be the grounding wire for the brakes. I thought it was a fluke, drove a self-tapping screw into the frame and secured the wire. I don't know how long it was disconnected but the brakes on that side would have been inoperative during that period.
Today I was repacking the wheel bearings and noticed the grounding wire on the passenger side was loose. Investigating I discovered the connector was not screwed to the frame but rather riveted. And when I was examining it, the rivet disintegrated and the connector and wire fell off. Again, I've now secured it with a proper bolt. I can't imagine why an important electrical connection would be secured with a pop rivet.
For those with brakes, I'd suggest you check this. I think all the Scamps now come with brakes so perhaps the wiring now is done differently. Hope so.
Edit: I was told the brakes on my trailer were self-adjusting so I didn't focus on that as a maintenance task. Turns out mine are not. I'm betting all the newer ones are. Just an FYI.
Sunfish
Sunfish's picture
Last seen: 1 year 1 month ago
broken ground wires, too
We have a used 2012 16-ft Scamp.  I also noticed the ground wires hanging down.   On our trailer, the ground wires go into tiny metal blocks.  The blocks were heavily corroded and the wires just corroded off.  I made new ground connections with screws and washers.  But, I still didn't have brakes.  I bought new brake assemblies and new bearings so I could be confident in their condition.  The brake pads were still good but the magnet was broken on one.  I bought ground blocks from Scamp and installed one.  I will check the ground wires regularly from now on.
ddshields
Same thing happened to us on
Same thing happened to us on our 2012 16 Deluxe, 6-7 years ago... that is, the grounding wires breaking off on both sides.
D Shields
