Manual 2004 13.
Fly girl
Manual 2004 13.
Just bought a 2004. My first camper. I ha e tons of questions.  Does anyone have a manual?  How do I tell if the fridge is propane or electric?  Will the AC run on 120v or does it need 30amp? All original equipment.  Can you search for a topic in the forum? Thank you in advance, Nancy
Hoosier Scamper
Hoosier Scamper's picture
Good luck!
Manuals would be hard to find. You will do better on here. A good RV mechanic would make a helpful tutor. Most RV fridges run off of propane,  AC, and DC. Look inside the drivers side panels and at the fridge controls. More expensive fridges swap sources automatically and less expensive ones are manual. The Air will run off of 120 alone but if you used much more it could be too heavy of a load. You may not have too many 120 items, mine are only the Air and the microwave then just anything I may plug in... I rarely use the fridge on 120 unless on shore power.
Carl
Sunnyone
Last seen: 2 months 5 days ago
Youtube videos
Nancy, here's a link to the Scamp youtube videos that give a lot of info. Some of them are for more modern versions of equipment, but you still might find them useful.
https://m.youtube.com/user/ScampTrailers/videos
