Flush water system
maryann509
Flush water system
Did I make this up or did I hear that you should flush your tanks before first use?
if you plan to drink from
if you plan to drink from them i would do that, it's new plastic that needs to be washed.  if you are just using the water for toilet/shower/cleaning dishes, then i wouldn't bother.
ColoCLW
I picked up some Camco
I picked up some Camco TastePURE Spring Fresh Water System Cleaner and Deodorizer for RV and Marine and a pump thing to run it thru before using for drinking. Does that need to be dumped at a Dump Station then?
We are heading up to Backus for an Aug 15 pick up!
Cheryl Winston
