Any help tracking down this sneaky leak?
10 posts / 0 new
JBR
JBR's picture
Last seen: 1 month 4 days ago
I have been finding a little water in the driver's side rearmost compartment of my 2017 16' Scamp. It's never much, tends to be only after a hard rain, and puddles under the wiring and water lines at the corner of the compartment. At first I thought maybe it was coming in through the electrical cord compartment, but don't think that any more. I sealed what I thought were all the possible external entry points (city water hookup, rear left side running light, even rear signal lights) as in pictures below. Anybody have experience with this or advice?
On our 2019 13 the water heater is in that corner and the lower inside corners  of the water heater sheet metal are not closed well/  where they are formed  at the bottom. Kind of a poor stamping of the inner sheet metal at the lower corners.   and when I washed the camper some water would get inside the Scamp. Also We had the top edge of the window by the stove that the white caulk was not adhered to the scamp fiberglass. It looked ok but I could easily lift it away and water might have been able to sneak in there too.
JBR
JBR's picture
Thanks for that. I'll double
Thanks for that. I'll double check on the caulking.
Jonathan Rockey
RamRod
Another Possibility
We found that water was coming into the same area from around the bolts that hold the spare tire.  Took the tire off, cleaned everything, and added butyl tape behind the nuts.  Been three years and no sign of leaking.
JBR
JBR's picture
After reading your comment
After reading your comment about the spare, I took mine off and wrapped the spindles with a bit of butyl tape. One of the inner nuts was in fact just a tiny bit loose, so maybe this is the culprit. It's all covered up for the winter now, but we'll see what happens. thanks.
Jonathan Rockey
yes this was happening to me.
yes this was happening to me.  looked and there was a very small screw hole in the wood.  turns out that hole was directly above the grey water tank.  when soap bubbles would get into the tank it could "fill up" (not actually fill, just more volume due to bubbles) and leak.  i got a lot bigger screw that was longer and zipped it in to plug it up.  haven't had any issues.  i also put the power converter up off the floor mounted on a 1"-2" block so if minor water ever does get in there, it won't hit the converter.
Cyaerislea
Cyaerislea's picture
Wrapping with butyl tape
Wrapping with butyl tape really works. But problems can also arise from damaged bolt threads. It may be necessary to replace them. When selecting bolts, pay attention to the bolt's thread pitch, length, and diameter. It is important to choose strong bolts with high strength values. At the same time, there is no need to choose more expensive products if you do not need such a nominal load or other increased performance. A wide range of fasteners is available at
https://www.scrooz.com.au/. Use only high-quality products from reliable manufacturers, but don't forget to save money.
SAugust
Last seen: 1 month 18 hours ago
Interior Lights Not Working
I have a 1980 16' Scamp.  Just installed a new battery, but interior lights are not working.  Have checked fuse (only found one) and ground wire.  Any suggestions?
Fuses
Was the one fuse you found at the battery itself?  Newer Scamp's have a 12V fuse box combined with 120 VAC circuit breakers.  Suggest to keep looking for more fuses, probably near the convertor.
SAugust
Fuses
Thanks, I'll keep looking, but there isn't a fuse by the battery.  The wire goes straight from the battery into the front of the trailer and into the storage compartment under the bunk (which is where the fuse was found).  Going to do more wire testing tomorrow.  It's so hot here (in San Joaquin Valley) I was getting grumpy.
