Door window
stv
stv's picture
Door window
I picked up a used 13' recently and on the way back the window on the door fell off on the way back from picking it up. I am not seeing that type/size on the Scamp parts site. Any suggestions on where to find one? I guess I could just get plexiglass and find a way to mount it.
You can see in my profile pick it is still on there when I made my first stop.
Plexiglass is your best bet
Plexiglass is your best bet unless there is a classic rv junk yard nearby. Your next issue will be finding a seal to fit. You may find a newer replacement window at places like this Windows RV Windows Trailer Windows (teardroptrailerparts.com) or Scamp. You will need a short window because of the arch in the door. On one trailer I bought the PO got a piece of smoked Lexan and pop riveted it over the hole in the shell for that type of window.
Sunfish
Sunfish's picture
Window, Call Scamp
I think you should call Scamp.  They should be able to tell you where they got the original window (brand) and what specifications you need.  I have found Scamp to be helpful.
