Actual weight 16
Actual weight 16
Can someone share their actual weight of a 16 #6 with bath. AC. awning and two LP tanks.  We have a 2019 13 with Bath no ac and it is heavier than the stated 1,500 ish.  We do not use it as a cargo trailer but do have a few items normally in a camper.
Always weigh more that stated
My deluxe floor plan looks like a mix of standard plan 6 and Deluxe plan B.
It was about 600 lbs over stated shipping weight.
thanks
Thank you for the real numbers. . Only major difference I might see is we would not be doing the Deluxe wood interior so a few pounds lighter there but minimal.  Then of course anything we add. We just put our 13 on a diet to see what we could lighten it by and came up with a few small things but minor.
How did the scale get the 260 tongue. Did you unhook?
does that include 2 propane
does that include 2 propane tanks and a battery?
Yes;with propane
No water, just as it came from the factory.
Here is a picture of it after my modifications and loaded ready for the road.
So far it is the second heaviest one that I know of now.I travel with ham radio, metal detector, magnet fishing. and camera equipment along with the usual camping things.(13 MPG towing with a 2016 f150)
porch light
I see your porch light differs drastically from our 2019 13. Is it a replacement?    I just swapped our Led Porch light for one that has White for illuminating the site or Amber for a real easy on the eyes night time clean up,and   less bugs. It was a pain in the rump since the original is riveted on from the inside and then the interior reflitix and rat fur is installed over the spot. Looked like an hour job and was like 3+ but nicer than the search light in your eyes.
Factory porch light
The factory porch light was always full of water. When I replace it I became aware that it was UP SIDE DOWN. The hitch light is the same type and has never had water.
I changed to the LED with the switch inside long before Scamp did, but cover it with tape because it is too bright.
