Winterize scamp
mm3670
mm3670's picture
Winterize scamp
Winterize Scamp 16 with air pressure
I had a truck camper for many years and blew the water out of the piping using a compressor at ~40psi hooked to the city water hookup. Sequentially open all the faucets multiple times until just air came out. Drained the water heater. Drained the fresh tank. NEVER had any problems and was nice not to have to use the pink stuff. It was stored outside in Colorado.
Do Scamps have a water drain plug at the low points like my camper did? I'm really asking for anyone with experience winterizing a Scamp with a compressor and had success. I know the pink stuff can work but would like to avoid. Also, the Scamp will be in my garage during the winter and it doesn't freeze in there, but we might winter dry camp.
Swetzel
Swetzel's picture
Winterize scamp with air pressure
I have a Scamp 13 and have the same question.  My Scamp will be store outdoors in Wisconsin.  I assume my fresh water tank valve is at a low point, is this true?
Steve Wetzel
2013 Scamp 13' Standard Layout 2
2008 Toyota Highlander V6
