Generator
Sheliaduncan
Sheliaduncan's picture
Generator
I have the 16 ft scamp .  Has anyone had success with adding generators to their trailer ?  I live in the south and now that we have a major hurricane on its way, wishing I had a backup plan for power.  Any advance would be appreciated.  Oh I am a single lady, so with that said weight is an issue
Last seen: 20 hours 16 min ago
WEN Gen
This is the one I use and it runs my AC and everything fine on the 97 Scamp 19.
https://amzn.to/32qmLn6
If a newer trailer it will probably do everything asked, but AC sometimes on the newer units might require adding an easy start setup on the AC.
2000Wen
I have the Harbor freight 2000 inverter similar to the Wen pictured. Some claim the same ratings and possibly same item.   It runs our AC and most items if used smart. a 1500 watt hair drier and a space heater would not work but if used one item at a time we have no real issue. Although it will not really run a Microwave if you are on that path, It is very minimal but works.
