Propane issue - fridge ok, stove won't stay lit
13 posts / 0 new
Last seen: 3 months 22 hours ago
Flap Inside Rubber Hose
I have seen this many times. If the crimp fittings are not properly installed the fitting can cut the hose as it  goes into the hose causing a flap. I have seen it mostly with hydraulic hoses but LPG hoses are about the same.
RocheACri woods
RocheACri woods's picture
And now you know the rest of the story
And the winner is...a new hose. I took the whole set up from hose from Scamp to the regulator, the new regulator, and hose from the regulator to the LP tank to a local heating and cooling contractor. I also took the old regulator to check to see if it still was working so I could keep it as back-up. A new hose from tank to regulator solved it, but the "rest of the story" as Paul Harvey would have said, was that the new regulator doesn't work.
Glad I didn't toss the old regulator and I've learned a few things in the process of troubleshooting. I also have a functioning stove so that is what counts!
