Search feature doesn't work
sddarkman619
How do I search for posts on here is the google search feature in the upper right doesn't show results for anything?
TIA.
Last seen: 10 hours 41 min ago
Just Tested
Just tested and search is working fine in Edge, Safari, and Chrome on multiple computers. Maybe you have settings on ur computer or browser that are blocking display on search.
What browser?
I have never had search work on Fire fox
sddarkman619
ok it works in other browsers
ok it works in other browsers but not firefox. which si what I use primarily.
Might want to look into that.
Search works with Firefox...
On my computer, the search works in Firefox if ad-block plus is turned off for scampowners.com.  Ad-Block Plus is a very common add-on to Firefox, so that might be the fix.  If an ad-blocker is in use (on any browser), that's the first thing to try if something doesn't work.
If it's been a long time, or someone else installed Ad-Block Plus, click on the red icon with ABP in it near the upper right corner of the Firefox browser.
Firefox
Just tested with Firefox, latest download and Search on SOI worked perfectly.
I'd say it probably is related to the use of an add on adblocker which would need to be disabled to use Firefox with search.
Yes...
It was the ad blocker in my case.
TNX
