Dual or Single LP Tank
ebrunner
ebrunner's picture
This one is for all of you experienced Scamp owners.  I've been tent camping for over 50 years, but never owned a camper.  My wife and I have finally broken down and ordered a Scamp 16' which will be completed in August.  I have vacillated between the single and dual LP tanks.  Our tow vehicle (2019 Ford Edg) has a tow capacity of 3500#, with a tongue weight 350#.  Our configuration includes the 3.7 fridge (3-way), bathroom, stove, and no furnace.  I don't believe we will be doing much "boondock" camping.  My question is:  am I going to regret going with the single LP tank?  I'm looking for opinions from all of you with experience and expertise.  Thanks
Tank with a gauge
I like to have the extra gas, when one runs out just switch over and refill when I find a good place to refill with LP (propane) gas.
With only one tank I'd be sure to use a tank with a float gauge.
And before someone asks...
... what else would you put in the LP tank
Propane and Butane,
When comparing propane and butane, the most important differences come down to the boiling point of the gases. Propane has a boiling temperature of -42°C, whilst butane has a higher boiling point at -2°C.
This means that propane will continue to vaporize and turn to gas in colder climates, which is perfect for the cold winters we get here in Ontario and for outdoor use. When stored as a liquid in a tank, propane also exerts a greater pressure than butane at the same temperature. This makes it more suitable for exterior storage and use. (Information copied from Budget Propane Corporation, Gravenhurst, Ontario)
Dual LPG Tanks
The only negative for two LPG tanks is tongue weight. I like being able to use one tank until it is empty and then switching to the other.
