2010 Scamp 13 manual sink pump rebuild.
Luxus panzer
The sink hand pump in my 2010 Scamp 13 has developed a small leak from where the handle goes into the body.
When taking scamp out of storage I found some antifreeze had leaked out on to the counter.  Also when I pumped fresh water thru the pipes to get the antifreeze out I noticed some small pieces or runner or plastic (desegregation of o-ring or grommet?) flushing out with the water.
Anyone know if this pump is able be rebuilt with some new seals?
Looking for experience before I rip it apart.
Last seen: 7 months 13 hours ago
Do you know the model # ?
I think this is for the current one. https://amzn.to/2Knt8if
Last seen: 2 weeks 6 days ago
Pump Leaks
Our 2015 Scamp developed the same leak. I fixed the leak by tightening the nut at the base of the handle. It is a plastic nut so just tighten it enough to stop the leak. You can also tighten the nut at the base of the spigot if a leak develops there.
Luxus panzer
Thanks. I will give that a
Thanks. I will give that a shot before ordering a rebuild kit.
