Valve under sink leaking
gcurry
Hi all, my wife and I bought a '16 Scamp last summer and when we were dewinterizing it we found a leak under the sink coming from a valve along the cold water line. It looks like it is a flow regulator or gate check valve of some sort, but I cannot find the exact part anywhere. Do any of you happen to know what this might specifically be? or if I can just use any three-quarter inch valve connecting the line?...
kdhanso
kdhanso's picture
Hot water shutoff
We have a 2016 19' that has a shutoff valve under the sink for the water heater. During the winterizing process, the idea behind it is to drain the water heater and then close the valve to keep water or antifreeze from entering the water heater tank. Perhaps the valve you are seeing is the same.
- Ken
