'95 Scamp 13 intermittent Beeping?
pastorruss.umc
Hi, we're new owners of a Scamp 13 and while checking the fit of some new curtains, while it is in storage, we noticed a beeping noise "beep beep beep" at a regular interval coming from the cabinet next to the door that houses the a/c. Since the battery is disconnected while in storage, we figured it might be a smoke detector that has running out of AA battery power. But search as we may, did not find the source of the beeping.
Any ideas would be greatly appreciated.
Russ
Beeping
A  smoke, CO2 or propane detector would be my first suggestion. A new one on me while searching for beeping was the Maxx Fan Deluxe with a remote. See link.
https://sprinter-source.com/forum/showthread.php?t=16181
Going Light
Still beeping?
Pastor Russ, is it still beeping? Do you have a carbon monoxide detector? It could be that. If so, check around for any potential sources of carbon monoxide. Like if your Scamp is in a garage, and you turn on and warm up your car in there, etc. If that's the problem, ventilate! And don't spend any unnecessary time in that area.
By the way: the CO detector is battery powered. Once you figure out what/where it is, be sure to change the batteries annually. Just like on the smoke detectors in your home.
Gene C
Last seen: 1 day 54 min ago
Beeping
We have a RV rental outlet, the beeping is generally low battery
Geno
