installing furnace in 2005 13ft Scamp.
mitemanx
 I am wanting to install furnace in my 2005 13 ft Scamp & am trying to determine the size of copper tubing going to my gas cooktop so I can install a tee. Any ideas? Flared joints?
3/8" Tubing
Scamp uses 3/8" copper tubing with flared joints. Make sure you buy copper tubing rated for gas lines. When installing your furnace it helps to make a wood mock up (bottom and back) to help line up your intake/ exhaust tube holes. There will be a diagram for drilling the holes in the manual but they are hard to line up without a mock up.
