Somewhat mysterious 12V problem.
deedee1
deedee1's picture
After taking our Scamp13 out of winter storage, when plugged in and connected to the TV all electrical seemed fine. However, when disconnected from the car I lost 12V. I thought it must be the converter so I tested battery voltage with the converter unplugged: 12.75V, when plugged in it went to 13.5 indicating a working converter.  All breakers are on and all fuses test good. It was working when I parked it.
Any ideas what i"m missing?
Last seen: 3 days 17 hours ago
Do you get it back when you plug back into the tow vehicle? The breakers are only for the 120 VAC so start following the voltage on the 12 VDC wires and fuses. Please let us now what you find. The  battery and converter both sound like they are connected to each other, but not to the Scamp lights etc. It's too new to be having a problem. BTW:  What is not working? Have you tried everything? Do not forget to check the ground wire of the circuits also.
deedee1
deedee1's picture
Yes it comes back when I plug
Yes it comes back when I plug back to the car. There is a row of 12V fuses next to the 120 breakers which all have the DC voltage to them and none are blown. I feel like I'm missing something obviouys; as soon as the sun comes up I'll recheck everything.
Ric Lied
I'm lost
If all of the fuses have power on both sides, pumps and lightsshould work unless the ground is open.
Good luck.
deedee1
deedee1's picture
After all that  it turns out
After all that  it turns out I missed one bad fuse. Thanks for the input!
Ric Lied
larry-new
larry-new's picture
Need a fuse tester...fuses
Need a fuse tester...fuses can look good but be blown where you can't see it.
If not now, when?
Larry
