New Scamp: Exterior Lights leak water
Hospadaruk
Last seen: 5 years 12 months ago
Hi!  Forgive if this has been asked before on these forums, but the Search box seems to be broken, and never returns any results...?
All of the exterior lights on my 2018 Scamp allow water to leak in, the gaskets seem to be installed OK, but they are made from some foam material (is it really closed cell?)   Do you have this problem and are there good solutions?
Last seen: 5 hours 26 min ago
Lights
Not familiar with the current lights Scamp is using, but being a 2018 model sounds like a warranty call to Scamp would be in order.
Not sure what the search issue is, I just entered “Scamp Lights Leaking” in the search box and got 10 pages of results. Anyone else not getting search results? If so, please report in the help desk forum so we can check it further.
Going Light
Last seen: 1 month 4 weeks ago
Search results
Hi Greg,
I used to have this problem (two years ago) when browsing using Safari and had to switch to Firefox to fix it. It might have been security settings in Safari that messed things up? But it's no longer an issue.
Search
Good to hear. I usually recommend trying a different browser when there is something going on with any website. I never use Safari, but I’ll check it to see if anything is happening.
Going Light
Safari works fine
Didn’t mean to imply it’s not a problem because I’m now using Firefox, because I’m not. Just meant that updates or perhaps my own settings changes have fixed it.
