Water leak in cabinet over dinette
Camille
We have a 06 16 feet scamp and there is water coming thruogh one of the 12 volt lights under the cabinet (over the dinette). Can't tell where it's coming from. Anyone have any similar problem or solution?
Last seen: 1 day 20 hours ago
Leaks
Check the rivets on the roof just above. If a cap is missing or the rivet is loose, there's the problem. Replace cap or install a new rivet or replace with a stainless steel bolt and nylock nut.
Last seen: 2 days 18 hours ago
Rivet
You can find rivet and snap cap replacement steps in the Maintenance Table of Contents.
