Furnace Thermostat Replacement
jn10601
I have a 2001 16' Scamp and would like to replace the existing (original thermostat is a Suburban mfg) thermostat just for the furnace.  I would like to replace with a one with a digital display.that also has a master on/off swithc  Any good experience or suggestions??
Jim
Duane M. Rykhus
Duane M. Rykhus's picture
Last seen: 2 years 1 week ago
Thermostat ?
We have a 13' 2017 with digital thermostat it works good but heater still is all heat or a little cold. i think its just the way it is no mater what you have. When at camp grounds with hookups we use an electric heater and its more consistent for keeping Scamp at a livable temp.
Have Scamp will travel !
Gompka
If you are looking for a
If you are looking for a direct replacement, i believe the popular one most people go with is this one
I have seen the same thermostate branded as Emerson and White Rogers so I believe they are one in the same.
Honeywell Pro 1000
I have had good luck with the Honeywell Pro 1000 (heat only). Make sure you carry extra fresh batteries. Very good install video. (not me) It can be bought from Amazon.
https://www.bing.com/videos/search?q=honeywell+1000+rv+install&qft=+filt...
chadstep
chadstep's picture
Last seen: 5 years 5 days ago
White and Rodgers thermostat from Scamp
Purchased the White and Rogers Digital Thermostat (incorrectly spelled on Scamp's website). I believe this is the introduction video for this particular model here: https://youtu.be/-HAYShiidGE
Included instructions from the new digital thermostat are difficult to use if you aren't an electrician. Here's a good look at the internals and an installation (not on a Scamp!) https://youtu.be/i2oYwEpoot4
I'm still working on getting the wiring to match correctly--please post a photo if you have done this work correctly to save me some time!
