Delta TV antenna
11 posts / 0 new
Carm-El
Delta TV antenna
Has  anyone upgraded from the old Delta TV antenna ?  If, so which Antenna did you replace it with and was there any problems installing it?
Payton
Delta TV antenna
I would also like to know if anyone has upgraded or modified the old antennas. Satellite perhaps? Removed altogether?
Mark
Last seen: 4 weeks 21 hours ago
Delta antenna removal
I removed a Delta antenna. I made a 3/16 aluminum plate to cover the hole.  My trailer had the original manuals, the Delta manual contained a template for mounting the antenna which I used to make the cover. I then mounted another omni antenna on the plate. If you install a King Jack antenna they sell a plate to cover old large antenna mounting holes. The main trick to getting the Delta off is aligning the knob slots to undo the set screws that hold on the knob.
For newer Jack. They also have one for the earlier model Jacks.
Carm-El
Delta Antenna
Thanks Eddie. I've been looking a the King Jacks. I'm going to try it. Whats the best caulk for RV roofs?
Sealant
Lexel, Dicor or 3M 5200.
skipper20
Were these stock or an add-on
Were these stock or an add-on? Used for Wi-Fi or actual TV viewing? Where in the trailer were they located?
Bill in Seattle
2003 Scamp 13
Bill in Seattle
Last seen: 1 week 3 days ago
stock or add-on ?
Delta and King were both installed by Scamp. Mine is the currently installed King.
I think location depends on year and model.
Jack install
If the Delta antenna hole is not too large for the Jack antenna the rivet holes can be filled using the Marine Tex. Then you won't have to use the adapter plate. Both antennas use a roof mounted RF cable. The Jack can be modified to use a cabin RF cable.
Carm-El
I have to look at the antenna
I have to look at the antenna, but cant the existing  cable be used for the King?
Roof cable
Your  existing cable should work if it is long enough.
skipper20
I guess it's all a matter of
I guess it's all a matter of personal preference but to me, camping is getting away from it all. Meaning no TV! If I feel I need to be entertained, I'll bring my Sirius/XM satellite radio. 100+ channels to choose from and all of them commercial-free.
Bill in Seattle
