3 " raise
Snow Gypsy
3 " raise
I know that to pull the 5th wheel with the class 2 or 3 truck you need to have a 3" raise on the 5th wheel.   My question is how can you tell visually looking at the scamp 5th wheel whether it has the raise on it or not?
Earl A.
Earl A.'s picture
ModeratorLifetime Member
3" Rise
When I bought my 5er, the factory asked what kind of vehicle would be pulling it and the distance from the ground to the top rail.  They said I would need a rise - so I know I have one.  How do I tell by looking at it visually?   Look under the trailer, right beside the wheel.  You will probably see a 3 inch by 1 or 2 inch tubular bar welded to the bottom side of the frame.  The axle will be sitting on that.  When I look at my trailer, the tubular bar is about 4 feet long.
When I bought my 5er, I had a '96 Chevy.  In 2012, I upgraded to a 2012 Silverado.  The side rails on the '96 were a little lower than on the 2012.  Originally I was concerned that the new rail heights would be a problem.  It didn't turn out to be a problem.  The only difference was less clearance between the truck rails and the trailer overhang.  Now there is 7 to 9 inch clearance and still leaves plenty of room for going around corners or traveling through dips.
- - Earl
Snow Gypsy
Thank you.  My husband posted this.  Looks like it wouldn't be that difficult to tell one from the other.  That really helps.
Cathy
5'er clearance
We do not have a Scamp 5'er.  But we did own for ca.10 years a 32' Jayco fifth wheel.  When we first brought it home, there was not enough clearance to back out of our driveway, given the drainage "dip" street-side.  So we had to raise the fifth wheel hitch a few inches. to give ca. 4-5 inches of clearance to the bed rails.  I would think 9" should be more than enough.  Is the trailer fairly level (for use when hitched to the truck)?
Snow Gypsy
Issue Would Be With Used
We are looking for the tow vehicle for a 5th wheel at this time but stalling since it looks like it will be difficult to find a used 5th wheel and if we go with a TT, don't want a truck at all.  We had seen one listed at a dealer a few states away but realized at that time, with a dealer especially, that we would need to match the 5th wheel with a truck when it comes to the rise.  If purchased from an owner, more simple since they usually let you know what they are towing with.  I have come to realize that all around, a TT is a simpler choice yet not really the best when it comes to space.  We'll get it worked out.  Thanks.
In edit, I have found a good article on someone's blog about conversion and towing with a SportTrak.  It just seems there is so much more to consider when towing a 5th wheel versus the TTs.  I still think the 5th wheel is just too cute though.
Cathy
