Viewing fresh water level in 2007 Scamp
Jswanson
Last seen: 1 year 1 month ago
Does anyone have any solutions to viewing the water level in the fresh water tank in a 2007 Scamp? I've read one suggestion of shining a flashlight on the side of the tank. Any other suggestions?
Tom in NM
Last seen: 1 week 6 days ago
What is tank material?
In my 2021, the water level is quite visible through the translucent tank. Sounds like that's not the case for you. What is your made of?
I have considered adding tank monitors. Scamps now come with them using a sensor strip that attaches to the outside of the tanks. They are a bit pricey though.
Last seen: 1 month 5 days ago
I replaced part of the
I replaced part of the removable board that is under the seat with a thick piece of Lexan, so I can see the forward facing side of the tank. This allows me to look there while only lifting a corner of the seat cushion. Yes, a flash light helps to see the water level and estimate the amount. It is not necessary to know it accurately. When it is to a few inches, it may be time to add some.
Last seen: 1 day 11 hours ago
We have an '06.  Set a
We have an '06.  Set a flashlight on the top of the tank.  Level is clearly visible.
