Small leak from bunk hinge
Rasmuspa
During the last rainstorm, I noticed a small leak of water coming into our 2015 Scamp 16 from the hinge point under the top bunk. The location of the bunk hinge leak was the one furthest from the door (drivers side). I'm curious if anyone else has had this issue. The only place I can think of this originating from is the clasp area for the window rock guard on the front. Not sure if I need to seal that up or what. Thanks for your help.
Last seen: 4 hours 2 min ago
Had the same problem with our
Had the same problem with our '06 a few years ago.  The screws from the outside that add stability to the molded in wood mounting for the hinges had rusted.  Replaced them with slightly larger SS screws and glue, new caulk and snap caps.  Problem solved.
