Good or Bad Idea ?
Duane M. Rykhus
Duane M. Rykhus's picture
Last seen: 4 months 1 day ago
Good or Bad Idea ?
Had to detach metal strap on axle for lift kit unsure what it realy dose anyway is it to support axle or floor ? Floor seems fine when two people are in it and my way of thinking axle should be ok.
Just working with what I have do not have a welder at this time.
Any thoughts would be appreciated.
creaky
We found the center metal strap weld cracked at the axle and the floor flexed a little bit and was creaky so I re-welded it and it firmed up the floor and no more squeak .  So  more likely floor support.
Last seen: 4 months 4 days ago
It's for floor support.  Very
It's for floor support.  Very interested if you notice any different handling with the lift on your 13', especially quick maneuvers at highway speeds.
