2018 16' wheel bearing and brake maintenance near Portland OR 97239
jdaberle
Does anyone know of a good trailer / mechanic to change the wheel bearings and do brake maintenance in Portland OR 97239? (or Vancouver Washington?) (2018 16') The driver's side brake is binding and that wheel wore unevenly. I hope I don't need a new axle. I read somewhere that sometimes the spindle can be "aligned / slightly bent back". (?) Thanks.
Try a utility / horse trailer
Try a utility / horse trailer shop. An RV dealer near me had a $240 deal to repack a single axle trailer. ($350 for a double axle trailer.) Most RV shops are really backed up in their repair shops. Deal with your brakes and bearings before worrying about a bent spindle. A loose bearing nut can cause bad tire wear.
