Screen Door Bi-Fold Help
Whaler19
My bi-fold screen door on my 2012 13' keeps falling out of the track.  I'm pretty mechanically inclined, and can't figure out what's happening.
Maybe a plastic piece broke away inside the top track.
Any Denver Colorado area owner have a screen door that I could look at?  Thanks, Brian
Last seen: 9 months 4 weeks ago
Pivot Bracket
Usually the upper pivot bracket screw loosens up allowing the bracket to slide away from the wall. It hard to get a good grip on a screwdriver to tighten the screw because the screen door has to be almost completely folded to tighten the screw. A screwdriver with a long shaft usually works. The screw is either a #2 or #3 phillips. Sometimes the track spreads where the bracket mounts you may have to squeeze the sides of the track to let the pivot bracket to tighten onto it.
Karen Hellyer
Karen Hellyer's picture
Not sure if you stabilize the
Not sure if you stabilize the door when you're driving, but I've found that a bungie cord holding it open / in place keeps it from vibrating so much while driving. I've definitely had it come off track because of the vibration from the road.
K. Hellyer
