Replacement window by rangetop. 2004 Scamp 13
ralphward388
Last seen: 3 years 12 months ago
The window by the range is broken and needs replacement. I have contacted Scamp online a couple of times and received no reply. The window behind the range is broken and needs to be replaced. Does anyone know where to get one? I did not see one on the Scamp site. It is the crank open type. Not quite sure why the image is rotated. Thanks Ralph
Last seen: 1 year 1 month ago
Window
With windows you need to call scamp parts dept. Have your measurements in hand when you call. If the regulator (arms and wheels) is broken you can just order the regulator from a window parts supplier. Some of the small windows were discontinued. Give Scamp a call first.
ralphward388
Thank you.
Thank you.
Ralph Ward
Scamp 13 Newbie
