Axel
Larry Pasley
Last seen: 12 years 2 months ago
Axel
I'm planning to change out the axel on my 13 foot 1991 Scamp. Is the torsion arm setting at 10% down as it appears?
Thanks,
Larry Pasley
Carlisle, AR. 72024
axle angles
. If you have a Dexter axle (4 sided tube) there should be a data tag attached to the axle. If you contact Dexter and give them the tag data info. they can tell you all the build specs. for your axle. Do your torsion arms face to the front or rear? Scamp installs 22.5 deg. up axles on the rear facing torsion arm S-13 trailers now. On the older S-13 foreward facing torsion arm trailers Scamp installed a 22.5 deg. down replacement axle on one I had them replace the axle on. This info. applies to the S-13 only.
