AXLE QUESTION on 2017 16'
Last seen: 4 hours 51 min ago
I am putting a 3.5" lift kit in my 2017 Scamp. The axle is bolted in BUT there is a welded strap in the center. What is it for?? I can't see it doing much more than preventing floor bounce when you walk on it. I'll weld in a short extension but it will not add anything to the suspension.
Last seen: 1 year 1 month ago
Floor support
You are correct it's just to support the floor. You are on track just weld or bolt in an extension.
TNX Eddie
I'll do a full report of the project when I get time. The easy answer to putting 14" tires on a 16' Scamp is that it can't be done (with out modifications). I'll show people how I did it.
