Up on blocks ?
Duane M. Rykhus
Duane M. Rykhus's picture
Up on blocks ?
Just but my 13' Scamp ( 70's Dream) away for the season just thought i would but it out there for discussion thinking of butting it up on blocks to take weight off suspension.
Last seen: 2 weeks 5 days ago
UP ON JACKS
Yes, get most of the weight off the axle by putting jack stands (or blocks) under the frame near the axle. I also have the stabilizer jacks down for safety, but not holding much weight.
JTST_Scamper
Placement
Jack stands ............ How many?
Do you place them on the frame on each side of the axle? So I guess I would need two per side?
Do you stay hitched to your TV or just chock the opposite side when jacking up one side?
I see the Scamp manual describes doing this for long periods of storage but never describes the best way to do it.
sorry for all the questions
Jeff
Jack stands
I only use 2 on my 16'. Just behind the axle. There is not much room to both jack it up and place a jack stand under there with out pinching a brake wire.     (mine is parked on a bed of rail road ties, so it cant roll.)
DPS
DPS's picture
Up
Just put ours up on jack stands Friday.
Doug
Rog Mich
So I put my jacks on, what I
So I put my jacks on, what I assume :), is the axle cover. I take it this is the wrong place?
<p>Roger and Michelle</p>
DPS
DPS's picture
Up
Yes.  The axle cover is not a good point.  I would move the stands to the frame. As soon as you can.  If you look up the axle manufacturer they say no.  When I jack ours up it is on a dirt floor of a pole barn so it doesn't move.  The wheel chocks sound like a good idea on the other wheel.
Doug
DPS
DPS's picture
Up again
I only use two jack stands on the frame of the Scamp as close to the axle as possible.  I don't have it hooked to TV while doing it.  I do have the tongue jack down on a 2 X6 making the trailer level front to back before starting to jack with a bottle jack. The floor of the barn is level.
Doug
