Shower in 16'
mojomedic
mojomedic's picture
Shower in 16'
Our 16' scamp has front bath/shower. Seems like drain is running slow pump doesn't seem to be very effective pumping out the water. Any ideas of what to do?
Last seen: 1 year 3 weeks ago
Shower pump filter
There is a shower pump filter between the shower drain trap trap and pump under the floor. You just unscrew the cap and clean the screen. I usually cleaned mine about once a year.
Shower drain slow
While the filter being clogged is the most likely problem, also inspect the plumbing.   This photo is of my Scamp at six months of age where the shower was never used, and only winterized.   I replaced the kinked hose and moved the clamp to restore the drain flow to maximum.
