New (and old) door lock
Eggman
Just replaced my door lock assembly with the paddle style
If anyone needs a complete setup from a 2016 (most likely the same from the beginning of time)
I have everything here (except the rivets I drilled out.
$10 plus $6.80 for priority shipping and it's yours
annie.coyne
replacing existing lock
Art and Luann,  I too want to replace the standard lock on my 2016 13' - but am somewhat intimidated by cutting the fiberglass.  Can you share the details of the process?
Last seen: 2 weeks 2 days ago
paddle style lock
What lock did you use? Standard RV lock? How did you add to the door thickness?
I would at least like to change the KEY.
TNX
Eggman
Locks
annie.coyne, the guide I went by to change the lock is in the forum in SOI, but it is not for the weak of heart. Cutting into the door is very nerve wracking and a certain McGuyver-ism is needed to make everything fit. For instance the strike plate outlined in the forum was made by a fellow that had access to welding equipment. When I went to a local welder he wanted $75 to weld a 6-1/2 inch piece to an 3/4 inch piece.....I found a substitute for $3.50 at Lowes that works fine.
ac0gv, this is the lock I used
Art
Adam Michaels
