Source for ensolite
wilber5059
Last seen: 11 years 4 months ago
Source for ensolite
Can someone give me a source for ensolite that will match early application, like a 1979 16'.  I have removed the plywood backing for the table connections and only need enough to cover that spot (approximately 3' square).
Dave Heffner
Roseburg, OR
ensolite
Look in the closet by the door or under your cabinets. You can remove it from those spaces and cover the places where it was removed from with refletix. I had to replace a tables support board in one trailer and covered the repaired area with marine vinyl that matched the color of the ensolite. I used a hot glue to attach the patch.
