Coax length for cable in campgrounds
Last seen: 1 year 4 days ago
Was wondering if there is a certain lenght of cable one should have to get from the connection on the trailers to get to the cable connection on the boxes at campgrounds,any ideas?
Antenna cable
Most trailer power cables are 25 ft. I would guess you could start with that length. You could also carry a butt connector and an extra 25 ft. section of cable if needed. Where is your tv connector on the C-16 is it in the upper rear corner like the one on the C-17
Last seen: 1 week 2 days ago
Cable
I've always carried a 25 and never needed anything else to date. At Scamp Camp SW the cable connection is right at the power connection area if I recall correctly, so you can estimate for that one for sure.
Thank you guys,he did make up his cables yesterday,we havent ever used the tv before,or had a cable connection in the Scamp.yes ours hooks up on the top back corner,must be the same as the 17ft.We mostly have camped at Zion without power and never really used the tv,just thought we ought to have the connections made,he also did up a shorter one that will go from the tv to the plug in the cabnit for the cable,we did not order the tv antenna up on top
