adding an addition 110 outlet to my 19 footer
priorlk3
Anyone ever added a a/c outlet to a 19 ft trailer?
Adding outlet
Just get an old work plastic box, the one where the ears flop out when you tighten it down. Cut a hole with a multi tool or other saw to match the box. Scamp just uses Romex house wiring , I usually use 12 ga. You can tap into another outlet or go back to the converter. If you add a ckt. you can buy a breaker from a big box store. You can buy outlets with USB jacks in them for charging. They usually run about $20 but worth it. If used outside or near water you need a ground fault outlet or breaker.
priorlk3
adding outlet
Thanks for all the help!
<p>Sandra Furlong&nbsp;</p>
