Add existing outlets
JackieA
I am picking up a new, already built 13' Scamp from the factory.  Evidently it is a canceled order.  It is too late to have Scamp install outlets.  Is this something I can have done at a later date?  From the specs online, it appears all outlets are options.  I would like inside 12v and 110 outlets and also the outside GFI.
Thank you!
Jackie
Last seen: 3 days 3 hours ago
Call Scamp
Congrats on ur soon to be trailer. Give Scamp trailers a call, they may still be able to add them since it is a fairly simple process. If not, not hard to add them later.
JackieA
I already asked them.  They
I already asked them.  They said it was too late for electrical wiring.  It's good to know it can be done at a later date.  Thank you!
Interesting Response
Guess they didn't want more $$.
As I said it isn't difficult to add them and we'll all help you walk through it when you're ready.
When is the pickup??
JackieA
July 31st. Thank you!
JackieA
I called Scamp back and asked
I called Scamp back and asked if I could have this done via their service department rather than an option.  I was told that's a possibility and to speak with the service department when I pick up the Scamp. That would be great!
Excellent
Hopefully they'll get you setup with what you want to add. 31st is real close, be safe on the adventure.
JackieA
Thank you!
Thank you!
