16ft Scamp, in need of measurements please
armypatti
armypatti's picture
Hi all! Future Scamp owner (Delivery set for mid Sept)
Does anyone happen to have the measurement of what will fit under the rear dinette when it's set up as a bed?
I am planning on it being a full time bed and them measurments would help alot with planning for some storage under there.
Width - Height - Depth please!
thanks so much in advance for the help!
mspgaff
mspgaff's picture
Measurements beneath rear table when down.
Patti, I'm going to pick up our 16' trailer at the farm tomorrow (Thurs) night as we are trekking for a few days.  If you can hang on, I will send measurements Thursday PM. Except on rare occasion we retain as bed full time also.  Barb
armypatti
armypatti's picture
thanks so much Barb!
"Scamping is better with Coffee"
mspgaff
mspgaff's picture
Measurements
Patti, think in terms of useable space for what you are planning.
Table length is 53 inches, HOWEVER, from back wall to step is only 44
Width is 30 inches
Height, this is where it gets more interesting.  When table is down in bed use position, from bottom to floor is only 13 inches.  Again, think in terms of useable space.  That would be 11 inches.  The "contraption" for lowering the legs is in the center of the table underneath, so that creates an obstruction of sorts.   For the moment, I've been using an "under the bed" plastic box with a tension rod to prevent the box from rolling out.  Patti, this is not the ideal solution, but useful.  The Scamp is not truly designed for storage, so I have items in there that would be useful and nice, but if not, they will be eliminated from inventory.   You learn quickly what you really need and what you can do without.   Barb
armypatti
armypatti's picture
thanks so much!
thanks so much!
I see what you mean about the support bar. Do you think if I remove it I could utilize the full 13 inches of height?
I love the picture! Looks like you have the deluxe. Is that the big bed or the standard?
