Subaru's towing specifications make absolutely no sense!!
AnthonyRM
Last seen: 4 years 6 days ago
The 2013 and earlier Foresters have a towing capacity of 2,400 lbs. with the 2.5 L 4 cylinder engine. The 2014 and later model Foresters have a towing capacity of 1,500 lbs.with the same engine. The CVT is not the culprit as the ratings for the standard transmissions are the same. The 2014 Outback with the same 4 cylinder 2.5L engine and torque specifications and weighing two to three hundred pounds more has a towing capacity of 2,700 lbs. The six cylinder is rated for 3,000 lbs., only 300 lbs. more than the 4 cylinder. I called my Subaru dealer and spoke with the service manager who had no logical explanation. I don't get it! Can anyone explain it?? Tony
JFreed
JFreed's picture
Subaru's towing
We didn't buy the Outback because the tongue weight was only rated at 200 pounds.  That didn't sound right to me.
I have a 2011 Outback. Subaru
I have a 2011 Outback. Subaru advertises a fairly decent tow weight but once you read the fine print in the owners manual it cuts the allowable tow weight by quite a bit. A single tank S-13 with brakes and flatland towing is all I would recommend. My next car will not be a Subaru for that reason. In reality with the tongue weight limitation the Subaru's should be only rated for 2K lbs. or less.
RocheACri woods
RocheACri woods's picture
Maybe it is some form of engineer logic?
When I bought my 2013 Outback they were touting the 2014 Forester re-design and improved fuel economy. Maybe they reconsidered the tow rating with the new design?
For what it is worth, I have friends who took a 6 month road trip with a refurbished Burro, which is admittedly lighter than a new Scamp, using a CR-V as their tow vehicle. (Same tow capacity as a Forester.) They weighed it before they left and packed very lightly for 2 adults and a toddler, but made the trip just fine.
