Adding a circuit to an existing Fuse Block
Sometimes you need to add an additional circuit for an accessory or to simply add an extra 12v plug inside your trailer.
Here is an easy, and safe, way to add that circuit without interfering with the original circuit...
Adding additional Circuits can be a relatively simple process if you use a  "Fuse Tap". The Fuse Tap is an ingenious device that lets you add a second circuit to an existing fused circuit.
If you have the "Plastic Type" fuses with two protruding prongs coming out of the base you simply pull an existing fuse and install the "Fuse Tap" in it's place, then, you re-install the fuse for the existing circuit and install another fuse (of the appropriate amperage) for the added circuit. This gives you two "Fused" circuits where only one existed before.
There are two common sizes for the "Plastic Type" fuses, ATO and ATM, the ATO is the "Standard" size and the ATM is the Mini version. If you are unsure of the size you need you can pull a fuse and go to the auto parts store and compare your fuse to the ones on display. You can then order the appropriately sized "Fuse Tap" using the links below, by-the-way, these are the best pricing available.
If you take a look at the pictures in the links I've included (below) you can see how easy these are to install (it's almost like Plug-N-Play)
First the ATO:
Littelfuse FHA200BP ATO Add-A-Circuit Kit
Next the ATM:
Pico 0956PT 10 Amp ATM Mini Blade Fuse Add-A-Circuit Fuse Holder
Please note, in reality, you will need to verify proper orientation of the Fuse Tap when installing. Install the fuse for the added circuit first, then verify continuity, next install the fuse for the original circuit (if you don't have continuity, simply turn the Fuse Tap around). The description used above was simplified for illustrative purposes.
PS: Fuse Taps are also available for "Glass" type fuses.
Handyman2679
Fuse tap
Thank you! I was wondering if such a thing was available.  I liked your original idea of using the cigar lighter (now called a "power point" - not to be confused with the MicroSoft  product smiley) but getting to any wiring inside the vehicle is almost impossible.  I was even thinking of creating something like this fuse tap.  This saves me a lot of time and trouble.
Handyman2679
Fuse Taps
Seems I spoke a bit too soon.  Seems that one of Ford's better ideas was to design a fuse block shaped so that only fuses fit!  The fuse tap is a great idea but won't fit in the socket!  But I'm determined to make that idea work so I am "deconstructing" a fuse and will use the prongs to solder to some feeder wires and will splice in a new fuse holder and fuse tap.
Cool Idea !!!
Cool Idea !!!
Handyman2679
Fuse Tap
OK, last update on this subject. My idea of " 'deconstructing' a fuse and will use the prongs to solder to some feeder wires and will splice in a new fuse holder and fuse tap" worked just fine.  But using the cigarette lighter fuse didn't - it's hot full time, not ignition sourced.  So it took a bit of probing with multimeter but I did find a switched fuse, tapped it, and all works well.
