Making counter space by covering sink and stove. Made tops by using 3/4 inch strips of maple, glued together and then planned to make smooth top. Finished with a gym floor sealer.
That looks GREAT !!!
Very nice solution.
Looks great. I am however more curious about the florescent light above. Your add on? Good lighting when I'm around prepping food is extremely important. Did you wire in or is it a plug in? I use a plugin here at home. Barb
Here is a great LED light bar that would be perfect for under your cabinets...
http://www.scampowners.com/forums/great-led-light-bar-replace-flourescent
I have paired mine with a USB battery pack and it eliminates any power drain from my battery.
Man with a Van I'll read up on that
No extra lighting,what looks like lighting on the counter is reflection from small window
Looks great! Nice job!
