converting porch light to LED option, how to?
painting scamp
Last seen: 10 years 3 weeks ago
Is there a simple way to convert the outdoor porch light to an LED option? It burns out quickly, would it make sense to convert the interior ones as well?
Changing Lights to LED
Here is an article, located under Resources, Solar for Scamps, which explains the benefits of changing your lighting to LED:
    http://www.scampowners.com/reducing-power-consumption-led-lighting
This article also explains the various LED options as well as links to LED lights available.
This should get you started on your LED conversion.
LED bulbs
Yes it is very easy to convert to LED bulbs. They are readily avialable all over, even Amazon. Get the equivalent of the 1156 type bulbs and they easily insert. I have done all of my bulbs inside and out with LED bulbs, very easy to install.
